I don't know how an engine could leak so much yet the source is impossible to find.
Oil seems to come from the front passenger side somewhere. It runs back along the pan rail. The catalytic converter and cross over is getting covered. Its dripping onto the paasenger X brace and the frame cross member is soaked. I changed the front seal about two months ago and the seal area is dry (it used to leak).
There is oil right below the turbo drain tube on a little cavity in the front cover but the drain tube seems dry. My oil cooler lines are brand new and dry. I replaced the filter adapter o ring. There is oil collecting on the filter low point.
I took a 3 hour drive and the engine went from a bit oily to soaked. Arrgh!!!
Is it possible for the front cover itself to be leaking through the gasket?
My oil pressure is great as always.
Help
Help
