well i was looking at my car the other day when it was on the lift. im trying to track down where my oil leak is coming from. it looks as if its coming between the heads and the block. i cant trace it any farther up then that. can this be possible? im going to put some die in the system and take a look but i was wondering if this could be. im almost 99% sure its not coming from the back of the intake. also it looks as if its coming from both sides drivers and passengers side in the same area. i really hope i dont have to pull the motor again. Nick might be mad and i cant afford to spend any more money on it right now. i still have to chaces down my false knock issue (i hope its false) once i get the car back. next step with that is to put C16 in it turn the boost as low as it will go and see if it knocks. its getting to me. i pulled the wastegate rod off and it wont knock but as soon as i set it as low as possible on pump gas and low boost as low as it will go it will knock. stupid thing. i dont want to hurt the motor. dont know what to do.
