Oil Leaking out of the turbo exhaust...
tuekwik4u
First time I post on this web site hoping to get some help. I recently bought a sand car with a Buick 231 with a turbo. From the number that is on the intake, it seems to be a 1980 Buick engine. Two issues I'm having....
One, what turbo did Buick use that year and two, I have oil leaking out of the exhaust pipe .... lots of oil, with a lot of white smoke! Would appreciate any help. Thanks.
They used one like this:
If you have that much oil in the exhaust and there isn't obvious thrust play be sure the drain back is adequate
It looks the same. Only this one has AiResearch M11 stamped on it. Do you know the actual name? Im trying to order a rebuild kit for it. Thanks!
