Oil Level With Rjc Engine Girdle?
REAPER231
The Power of the Darkside!!!
Hey Guys Where Should The Oil Level Be On The Dipstick With Rjc Engine Girdle With Factory Oil Pan ? I Have The Rjc Girdle With Crank Scaper And Biggie Oil Filter. I Filled It To The Add Line Where Its Says Add One Full Qt . Is This Right , Thanks For The Help .
I always run 3/4-1 qt low with either setup to keep windage and such down.
I run mine about half quart low according to dipstick...I also have the crankshaft scraper...think it about though...all you have done with the girdle is lowered the pan 3/4"...so running it at the stock dipstick level is no different..except now you have more oil in the pan...
That's a good question. I was told to run it about a 1/2 quart low per the dipstick - but what MSDGN says makes sense. All that happened is that your oil pan is lower, why not fill to the full mark on the dip stick?
