Oil line upgrade
Whatever return line you use be sure the cross sectional area at it's smallest point is at least the size of the stock line. The stock line is very repeatable and has worked for almost 30 years.
Am I missing something here? Unless I have you mixed up with someone else you ordered one of my turbo protector kits and you should be all set with what I have sent? AF from Bellmore NY right?
Mark, you are right this is AL, I guess it was missing an adapter... The fitting at the end of the line is a female and the turbo is a fitting female... So I went in the pouring rain to my local over price speed shop and they knew what I needed.... Done....
