oil lines
T-Type85David
gonna replace my lines, wondering what kit is out there if not. any1use those ebay oil lines??? As for our drain outs look fine to me, in size. but idk any feedback on new lines for out cars guys?? or a DIY kit somewhere??
PART 2
Those oil line filters, anyone using?? whats the word on them?? thanks god bless, n happy holly days guys
I am assuming you are referring to transmission oil lines -Postons-Turbo drain lines-Postons. Other options maybe GBODYPARTS. Good luck- Brad
opps!! damn, i meant the oil lines from the turbo, out&in feed&return, tom&jerry,david spade& chris farley etc sorry. Whats this about lines that block some of the oil going into the turbo?? is this needed?? a risk or a must?? thanks
The answer is Postons. They have the oil feed line to the turbo as well as the drain tube into the intake manifold. Forget the website and call them on the phone-better service. Brad
your local NAPA has a stock oil feed line for about $15. not sure about the return line, tho.
You have a part number on that? or what they need to look it up as my guys can't seem to find it listed. They do have straight line I can bend to fit. For $15 I would rather not.
So do our TRs need this eBay Motors: 36" Turbo Oil Feed Line Kit TD05H T3 T4 T04E T70 EG EK (item 120346343402 end time Dec-14-08 11:54:54 PST) or the Adaptor Limits Oil Flow??:confused: :confused: I'm about to get my turbo back n i was gonna get the napa line. IS the factory unit fine or do we really need a adaptor that limits oil so it won't blow through the seals?? get back to me ASAP:confused:
Try posting your cars modifications in your signature. If you have an 85 the oil feed line on the link is a complete waste of your money and time. Zero performance increase-just a predator of ebay trying to empty your wallet and your time. My 2 cents. Brad
then should i even need a new oil line? i have a spare n it looks like alot of build up are in the lines??:confused does this mean maybe the one i have now could be the same. I guess im gonna have to take it off n check but napa line is a 90% buy im sure. Yeah ebay lines i realyl didn't buy into all that.
