Please help.
I just got a replacement '92 Camaro aluminum radiator for my 87 Turbo-T. It only has one tank on the passenger side (input lines are facing the engine). Should I run my trans line here for cooling or my oil lines (which ones fit)? I will buy an external B&M cooler for the one not used here.
What are you guys running?
Can the oil line just run to an external B&M tank only?
I have room for two external B&M tanks if needed.
Thanks,
Brandon
Thanks,
Brandon
