German Specs,
Good-n-tighten, hope you used a cork oil pan gasket, those rubber ones leak-um all over the place. I just snug the bolts down where it doesnt cuase the gasket to split.
I used a cork detroit gasket on mine, installed the gasket dry, and so far not a drop on the floor in 600 miles since I built it.
Hope you also did the "rite stuff" silicon to the rear main seal and not used the push pins.
Good luck,
