Oil Pan Bolts
TurboTJT
What are the specs for the two different sized bolts for the oil pan?
What's the quantity of each?
I might be off by one but in think there are 14 5/16-18 with washer head and 3 5/16-18 with captive washer and 8x1.25 studs on them. There are 3 1/4-20 washer head on the front of the pan.
What is the stud spec for the (3) 1/4-20 bolts for the front of the pan?
The front 1/4-20 are bolts. There are 16 5/16-18 bolts, and one 5/16-18 captive washer with a 8mmx1.25 stud for the transmission line clip. I believe the bolts are all 1" length.
Tim, forcefed 3.8's is right. Here is a correct set of 86-87 pan bolts.
