Oil Pan Drain Plug...
lethal231ci
The Next Generation
Looking for an oil pan drain plug, last time I got my oil changed, they stripped my bolt.
Let me know guys, thanks!
You take your car to get the oil changed:confused::eek:
They have oil pan bolts to restablish threads in most parts stores
I agree ^^^
You can get them slightly larger than your old bolt self tapping. They have a nice little magnet on them so any shavings will be grabbed right away and not make it through the engine.
it is a 1/2x20 thread, is the plug screwed or the pan itself as well, I would bet just the plug, get that size and it should screw right on in, use copper or nylon gasket and about 15 or so lb. ft. tq. to tighten, if in the pan as well you
will need a tap as well to chase the threads, HTH
Ron
