whitehot1...you posted just before I did...sorry,
You may have already checked the below AND know as well, but just my .02 input to help out:
1) Have you overfilled the oil pan...pan upgrade holds 7.5 quarts...when checking your oil dipstick should read 1 quart low--I have same RJC pan and Girdle setup.
2) Have you completely wiped off the oil location where it leaks...(and definitely let the TR sit overnight)....this way you know the car has not moved, no motion to move oil aroundthe lip of the oil pan
3) ALSO check both your valve cover gaskets...run your finger or a paper towel under them to see if oil is leaking from there, which inturn down the block to the oil pan. Ask me how I know!
4) Over torque of the pan bolts "may possibly" be the culprit as well, although you mentioned torqued to spec
