David have you looked into the new Cometic oil pan gasket? Ive heard good things but have not personally used one. The only reason to get rid of the dimples on the pan was if you were using the thicker cork gasket from RJC that did not have the extra holes for the dimples to protrude through(the only holes in the gasket were bolt holes), and even then I don't believe you have to.
