Oil pickup bolts
Seen it used at work before, takes the special pliers that spin right ? How would I use it in this application because I can deff get hold of the wire and pliers if needed.
What is the right replacement oil pump pickup? I have a 20 bolt pan looks to be 5 1/2 inches deep. Napa sells 3 different ones 5 3/8 seems to be the closest. Is this the right one?
Hey never heard of safety wire earl can you explain and what size do I need was able to get one bolt in eith lock tight but the bolt towards the front of the motor is giving me a harder time can't get a wrench in there i have a small one thinking a craw foot.
I use a 1/4” drive socket & extension. Good & tight w/ loctite
If that joint leaks you’ll get air sucked into the oil pump. Makes for a poor oil pressure situation where oil pressure actually drops with increasing rpm
Here are the safety wire pliers needed
For onzise, twosises you can get by with pliers or Vice Grips, instead of buying the expensive pliers.
This kit would probably be a better bang for the buck for rare uses. Amazon.com
I used to roadrace and had to wire everything on my racebikes, so I tend to use it on anything important that holds back fluids or international fasteners.
Keeps fasteners from backing out and doubles as a visual assurance that they are torqued.
