Oil pouring out past convertor seal
jerebear
I have an 87 G.N.,180,000 miles, eng and trans never rebuilt, suddenly developed a serious convertor leak, after torqueing it up on the street, So pulled trans, put seal, still leaked, then later pulled and put 2800 stall convertor, and another seal,, still leaked, So started research on here, decided to put bushing too, pulled her again, fabricated a device to clamp on stator, pulled front pump, :D , and found the bushing had moved out about a 1/4", So put a new one, with locktite, reassemble,, and no leak!
Obviously, the bushing was touching the lips of the seal, when torque convertor was in place. Also drilled out the seal drainback hole.
I love this site, and am keeping my G.N. for the rest of my live, and I am 55, She is basically stock, except for larger turbo, K.&N. filter, Chip, and adjustable fuel pressure regulator, New timing chain, and bearings, When the chain failed, the trapdoor in the pickup screen lodged open, and she sucked up some of the chunks of the plastic coated cam gear, found some in the journal holes, also, after this developed a loss of oil pressure, and I found a chunk keeping the oil pressure regulator from bottoming, dumping most of the oil pressure, Needless to say, I put a pickup tube from Napa on, and now have a heavy duty chain. I recommend replacing that stock chain and gears before they fail.
Welcome to the board, Jerry.
Glad you got it fixed!
There is one strange thing though. While front seal blowouts/walking pump bushings was a common malady on 2004R/700R4 transmissions, Hydramatic did provide some relief in 1987 by machining a retaining step in the bushing bore to prevent the bushing from walking forward. I've never heard of a 1987-up pump having the bushing walk past that retainer.
Are you sure the transmission was never serviced before where it possibly received an earlier model pump body?
