just did your test. the gauge does go to zero when I ground the signal wire. The sender has no tape on it and it was grounded, I checked it with a trouble light. Pulled the sender and there is something broken inside, it rattles.So now i guess the sending unit is the problem. I had ran a wire from the sender to the gauge earlier, it did nothing. Also the sender rattles if you shake it.
