Oct 1, 2012 #1 J JIm Duda New Member Joined Jul 30, 2012 Messages 17 At cold start the oil pressure is 82 psi. Is this common? If not, what is normal?
Oct 1, 2012 #2 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 Do a search....very well beaten subject
Oct 1, 2012 #4 Q QUIP'6' Brian Roman Joined Nov 26, 2003 Messages 4,381 they all vary depends on bearing clearances and casting flaws in cover. pump clearance and gear and plate condition as well as oil viscosity. as long as your idle hot pressure rises 10 per 1000 rpm. even 10 hot idle is normal
