Oil pressure gauge
Dhos1
Self-tuning wanna-be
for an install of a oil pressure gauge I can tee into the turbo oil feed fitting on the top of the turbo correct?
Awful hot place to set that up. I think most of use T into the bottom of that line down by the oil pump where the stock oil pressure sender is. If you go electric, try a manual gauge first since the electric may read different. My electric read 10 psi low when I had both hooked up at the same time.
If you connect at the turbo use copper line it works fine, unless theres a restrictor in the turbo like with some bb. turbos.
