Oil pressure sending unit?
Spot1984
Where is the oil pressure sending unit on 87 Grand National? I bought a new autometer gauge and was wondering how to correctly install the sending unit? I'm new to grand national's but I really would appreciate the help. Post pics if you have them.
Look at where the turbo center section lube feed ties in at the lower front pass side of the engine. Plumb in a tee there, add the sender and walla
behind the lower rad hose where it comes off the waterpump
and no real need for a Tee , just unscrew the stock sender switch and screw in the new sender unit , some need and include an adapter reducer but most are the same size threads as the OE switch
be sure to bring the wires from the OE up and wrap and secure them so they cant ground out
