turbonut85
Rarely used member
- Apr 11, 2008
So I took the GN to a local show yesterday....Here is what I noticed: Upon start-up...with engine cold I had about 50-55 psi on the oil pressure gauge. The more I drove it, and the hotter it got, the pressure would drop with the RPMs...all the way down to 10 lbs in drive, stopped at a light. What would cause this?? Also, car puffs blue smoke upon start-up and has a burning oil smell in the exhaust...but I can only see it intermittenly. Could this be a bad seal in the turbo?? Are these two problems likely to be related?? If the seal was bad in the turbo, could it be leaking exhaust into the center section of the turbo thus heating the oil and thinning it out?? Would that cause the drop in oil pressure?? Help me out here
---Keith
