Oil Pressure Switch Connector Options?
hawkfan
TurboBuick.Com Supporter!
I was removing my stock turbo oil feed line(installing a Turbo Protector) and attempted to unplug the oil pressure switch connector to get some more room. BIG mistake. It 'smushed' and crumbled like a moist piece of cake leaving only the bare wires in place. It's obvious years of oil leaking from the breather tube(recently deleted) soaked the connector and wires and ruined them. Are there any replacement pig tails available to replace the connector and about 2-3" of bare wire that's left? None of the connectors on Rockauto seem to match. I know heat shrink and female spades would probably work, but I want know if there's a better way.
Caspers is probably the best place to start. This is a common issue with these car for the exact reason you cited.
I don't know why I overlooked Caspers. Just ordered the connector from them. Thanks.
