Oil pump gear cover qtorque spec.
BoostKillsStres
TIRE-FRYER VIA HAIR-DRYER
Is this reference on the gnttype.org site the correct value for the plate that covers the oil pump gears? I checked mine at 120 in/lbs aka 10ft/lbs using an old pointer type torque wrence and the clearence is just a hair larger than .003 using plastigauge across the gears I figure it will be right at .003 at the below value. I have to wait and borrow a in/lbs wrench before the final check.
Oil Pump Cover to Timing Chain Cover 141 in/lbs.
