eastwoodad
- May 23, 2003
I just installed my oil pump in the front cover and had a question. The oil pump cover was slightly scored so i trued it up a little with some fine emery cloth on a block. I did the same to the face of the front cover where the gears are, not much but just to clean up the surface.
My question is, once I installed the gears and the oil pump cover and tightened things down using the supplied gasket, it is pretty hard to turn the pump gears by hand. Is this normal? Did I maybe take too much off of the face of the oil pump on the front cover? I think I know the safe answer is to pull the pump cover and measure the gear clearance to the oil pump cover. What clearance should I be looking for? If I did take too much off, how do I gain extra clearance...with an extra gasket?
Thanks,
Aaron
Thanks,
Aaron
