im going to be doing my timing chain soon, partly because its at 100k and partly because i have low oil pressure(12 psi hot idle) ive heard that when dropping the pan there might be pieces of the rear main on the pickup, which causes low pressure.
my question is, if i do the timing chain and rear main and then put it all back together and see if the pressure goes up, woul di have to remove the timing cover again to rebuild the pump? reason is id rather not touch the pump if i dont have to. If i do have to rebuild it, id just do a stock rebuild on it, so can that be done with the timing cover on the caR?? TIA
