oil pump
Usually they tell you the pressure of each color. Look at the coils & go with the weakest one or middle strength one but usually blue or yellow I think??
Gotta look as I have a bag of springs from over time. Still I seem to remember yellow for some reason?
I have many as well the problem is that the shop that put my motor together put the spring in and left me a box with the rest and told me to put the one in that I wanted. The spairs are in the box with out the instruction sheet any way thanks I will prime it with that one and double check.
Use the Yellow for 60 lb & you are fine. Its not super critical for the bypass spring if its 60 or 70 lbs.
