Corky Bell's book talks about oiling a little bit.
1. He says that too much oil pressure can create problems, and that it is possible to force oil past perfectly good seals if the pressure at the turbo exceeds 65-70 psi.
2. symptoms of oil getting past the seals would be frequent but not quite constant smoking. Solution is to add a restrictor or bypass to the oil feed line.
3. Restrictor: a 0.055-0.065" orifice in the turbo oil feed line. He recommends installing a pressure gauge downstream of the restrictor to prove there is adequate pressure at the turbo.
4. Bypass - tee at the point where oil goes into the turbo, one end of the tee goes into the turbo, the other end goes back to the engine (into the pan I would presume). Bypass line back to the engine gets a restrictor in it so it doesn't starve the turbo completely, just diverts some oil away from it.
5. Actual oiling requirements (for almost all turbos he says): at hot idle the turbo needs 5 psi and 0.1 gpm. At maximum load it needs 25 psi and 0.5 gpm.
