Oiling suggestions.
turbowrenchhead
Drive like you stole it!
I took apart my stock front cover and oil pump. I got some information on ruggles modifactions to the stock pumps. It must be pre SFI because the pic of the pump does not look like mine. It requires the making of a 1/8 thick plate and some drilling into the pump. I dont see how this plate can work for our applications. They also want to drill smaller holes for the cam bearings and turn the stock holes out of the oil feed. This will elminate "internal oil leaks". This I think is a good idea. The reason they had the cam oiling holes so large is that sludge buildup over time would plug up a smaller hole. If you change your oil regularly you won't have to worry about that. But If I have this done I don't think I want alot of oil pressure. So I am back to square one. Do I go with a HV cover with stock pump and spring and a booster plate or no booster plate witht the smaller oiling holes in the cam beargins.
See previous post "Do I need a HV cover"
oil
Recieved e-mail---The Ruggles book was written in 1982.( I believe.) I had some spacer made off that drawing. They work for me, no alignment problem. Without seeing this in person, it is hard to say what is going on.
IMO a properly worked stock cover and the other tricks are all that is needed for sufficient oil pressure. HOT oil pressure--22@ idle---60 @2000 rpm
I don't know how to go about refining the stocker. There is only information in the book about the plate and a couple holes that need to be drilled. If it helps, my pump looks like the one pictured on page 25 with the diagram of the plate. Then i think its on page 23 there is a completly different pump pictured.
