- May 28, 2001
FAST is installed.
Car starts OK when it is cold.
Idling is the problem. The best idle speed seems to be 900 rpms.
The biggest concern is that the motor is running very rough at idle to 1500 rpms, after that it smooths out and runs nicely.
Took it out around the block and it stumbles around until you rev up some. Same problem it sounds like to me.
I have tried changing the VE values at and around idle, it helped but did not solve it. E.G. value in cells at idle( bottom left corner was 43 changed it to 26, it did help.) Any lower and the car would die on us. A/F ratio is 13.3 in corresponding cells.
I am getting a backfire every now and then. Dont know if it is exhaust or intake.
Now here is the other problem. Crank Reference Angle. As I understand it this allows for any mechanical timing that has been setup on the crank.
So here is where we are. The crank sensor is set at 24* BTDC. I have tried the Crank reference angle setting at 14 BTDC. According to the book you are supposed to allow 10* for the ECM to make its calculations prior to the timing event. No help, it is still running rough and we have a stumble at low rpms. I tried the default setting of 10, no help. Tried 24 that did not help either.
Suggestions anyone?
I am having a beer and trying to ponder all of this.
Thanks in advance.
Suggestions anyone?
Thanks in advance.
