Well I was under the assumption the chip had some degree of boost control capability. Not the case?  I installed a TT chip set to 18lbs. Thing would run good under lighter throttle but would fall on it’s face sometimes under full throttle.  I’m guessing too much fuel.  Have a boost gauge to go in along with all the other supporting mods ie walbro 255, hot wire, 60# injectors, and adj FPR  but I guess I’ll need some sort of boost control.  If that is the case what’s the go to boost controller for ease of use?
Thanks,
Erik
			Thanks,
Erik
