blackgn231
Money pit
- Mar 28, 2007
I was using plastigage oh I know not good but all ,I had well all my mains came out with a .0002 reading not good huh,well I put my friends new crank which was cut the same as mine 10/10 and got the same readings so what gives both cranks bad of bad set of bearing? Summit said that some engine builders buy two to three sets of bearing and mix match them till they get the correct clearances. Not sure whats going on the rods read .0015 which is what I had hoped for the mains.I did torque one main by torquing it then loosening it up and retorquing it and got a better reading so what gives anyone?
