blackgn231
Money pit
- Mar 28, 2007
I got both new lines brake lines on the front after a bad one from advance, may have let the fluid run out when I did this for the 10th time,So would this mean that ,I now have to bleed the power master now? I have depressized the acculator to get all the brown fliud out , now should ,I pressurize the system back up before trying to bleed the system?And since ,I did not do anything to my back brakes do,I need to bleed these also?I tried to see how the backs worked and they are hard to get to for sure, only could get to them using a small socket. How the heck does anyone bleed them they are recssed back so far you can't get a open end wrench on them.I tried to do the front passenger side got clean fluid out of it ,but did not pump up the system yet ,I think it would make it easlier to bleed?Ok any help.
