fordkiller
- Nov 12, 2005
Hey there,
Getting back into the GN game after a long break... I've got a used engine I'm tearing apart to take a look at and might use short-term to get my car running again until I put together another engine I've needed to assemble for a while.
The used engine has .030 pistons (with no name on them like TRW, etc.) and the bore looks good with a lot of cross-hatch left and no noticeable ridge in the top of the cylinder so I'm willing to chance it and see how things go. What concerns me is the crank is at .020 on the mains AND rods! I've heard in the past that these cranks shouldn't be turned past .010 due to the fillets and the strength lost due to more material being ground off. Some of the main bearings had some dark discoloration in spots but the crank looks shiny and smooth still. I was planning on replacing all the bearings anyway but I wonder if something is going on why I'm getting the partial dark discoloration on the mains bearing surfaces.
I pulled the cam out to hopefully see what was in there and all I could find on the end of it were the numbers "F143" on the top and "930406" under the top number. I've Googled the numbers and don't come up with anything. Also it had no swirls machined into it like a stock cam I had from way back that had no numbers on the front of the cam but it did have swirling machined into the front of it.
Ideas on using this engine short term? If it wears out/blows up it's OK; I have the other one to fall back on. I know the engine is probably at it's limits as far as the crank goes and it being .030 for the pistons. Any ideas on what cam this car has?
Thanks,
DH
Thanks,
DH
