Old hose at front of right Valve Cover
mikeelia
Mine is long gone with a breather there. Does anyone have an original diagram showing how the original was run? I have to get my 87 smog tested here in Kalifornia. Bought a 'regular' oil filler cap at Autozone for that day...
Mike
No diagram. The hose went from the ft of the cover, to a nipple on the turbo intake. The original turbo has a bolt on intake. If the car has an aftermkt turbo, that bolt on may be gone, and the turbo compressor is 1 piece. What do you have?
Got it smoged yet? That breather on valve cover may be the original (otherwise would be hard find one that fits). Origiinal one is odd shaped & has about 1/2" hole with odd-shaped grommet fitted into it, then a hose (about 1/2") over to turbo intake nipple. If you no hosing in place, that nipple probably has a stopper or such over it closing it off. So, remove that stopper and run tubing between the two. Good luck.
