on center block and stage 2 heads
On center block and stage 2 heads ported by nascar stamped with rockers for 2000 ....good deal or not and what's the capabilites I can get with it? Thanks george
Sounds like a good deal if the block is in decent shape. Do your research on the parts though:
on center block means adapting a carb'ed intake to EFI - $300ish
rods are $1,300 for good on centers (new)
on center doesn't have an oil pickup so you have to run either a dry sump setup or TA/Dutt style oil pump with a pickup ran to the pan - $500+?
stage heads will require custom headers $1500-2000?
stage heads will require a custom cam (SII specific) $350 @ Comp
etc, etc, etc
Cam make ridiculous power, but take some serious cash or fab work for the supporting parts.
For a good stage block and heads, that's a smoking deal. Like mentioned before, building it will not be cheap
well the story is my uncle in NC hangs out with all the old nascar guys ,like engine builders that built for nascar and the guy has 4 of the blocks,heads up the azz and rods crank ect ect ,he told me 500 a block and there good ,its the heads and rockers that he is taxin on,my uncle said you wouldn't belive the stuff these guys got just sitting in corners of there garage , ford 427 duel quads ,hemis all types of bs,i guess when you owen bentlys and stuff you really dont care about the little things....o_O
so your gonna spread the wealth right? lol
i got the money hunny if they got the goods! needs me some stage stuffs!
Buy the blocks and let him keep the heads. There are plenty of sets of Stage II heads out there that no one is using. I've got a couple of sets I'd sell you cheap. The blocks are the hardest parts to get and are worth the most money. Check to see if he has any good cranks too. :cool:
Neal
Neal
really? what kind of cheap we talking? i need heads more then blocks~!
ok so we had a misunderstanding on the blocks :rolleyes: my fault but i think were still gold this is along list and about 50 pics 2 oncenter blocks one has bbc cam journels and .903 bronze lifter bores,pan rail is cut for windage tray /have pan cam and jesel 903 lifters for block 4.030 /2nd block is a std that was in nascar 4.000 bore was blown up and fixed was checked and used ,good block 1,200 for std block and 1,500 for outher block with cam and 9.03 jesel lifter and custom oil pan...3 sets of pistons new diamond 4.040 bore 3.625 strk $500...2 stock timing covers modified and weled for gear drives $200...4 oil pans hamburger custom for block cut for windage 2 ruggles pans road race and 1 deep pan pans have 12an fittings for dry sump $175 each .....4 sets of stage2 heads 2 sets use shaft rockers i have one set of jesel rockers 2 sets of stands and spares 1 set of crane shaft rockers ...2 sets of heads use jesel stands and rockers ...all heads use 2.100 int/1.65ex valves 800 for bare set or 1,500 for complete set ......5 intakes 3 sheetmetal 2 made by tim cole ,2x4 and single tops ,1 hogan with both 4150 single and 4500 style single carb tops /2 cast intakes with strait runners 1 brand new from gm racing outher one run in nascar $1,200 for the hogan $800 for the outher sheetmetal cast single plane $200.....couple roller cams this cam only goes with the bbc journel engine 840'int/760'ex 1 ta performance new in box 4340 forged 3.625 stroke $700 rods new in box billit h beam k 1 technoliges 6.350 with arp bolts $500 multiple sets of stage 2 headers coated and stainless diffrent primary tube sizes $800 for stainless and $600 for outher headers have merge collecters also fluid dampner 300...fisher balencer 250 ...msd dist 200...mildion gear drive 275... weaver stage 3 dry sump pump 400....tci rattler balencer 150...gaskets ect ect....ok i dont know what the stuff goes for or priceing guys and sorry for the $500 block f...up :oops: but this is the list and i have pics ..here you go
pics
pics
pics
more
That's the stuff that Alex has had up for sale for a while now on RacingJunk.com. I bought a crank and rods from him last year he's a really nice guy.
Neal
