S
stevec
Guest
The on-center motor appears to be .120 longer than the off center motors. The extra lenght is at the front of the motor because of the cross bolt mains I assume. So when mocking up the front cover the two oil pan bolts in the cover need to be re-drilled. No problem. My question is this will there be an interference problem between the harmonic balancer interuppter ring and the CPS. With the cover moved out .120 makes it closer to the ring. The crankshaft and balancer length did not change any. I dont think making a spacer for the crank would be the best way if they were a problem. I am going to mock this up soon and will let you know what I find. I was just wondering if some of you guys have been there done that.
BTW I am using a BHJ balancer, stock 3.8 front cover, and scat crankshaft. The cover will use duttwiler oiling.
Other mods to the cover include welding up the area on the bottom of the cover motor sealing side and milling flat. The on center block has no meat in this area. So you will get an nasty oil leak.
On more thing, I recall seeing a l reference to this issue in the Buick Stage II Racing Guide by Dave Emanuel. He was describing the difference between the two blocks stating that the on center required special connecting rods and intake, same crankshaft, camshaft, and cam drive as the offset bore blocks but required shortened front cover.
The part number for this cover is 2550169. The only problem is there is no place to mount an oil pump on this cover. I have thought about shortening a stock cover, there looks to be enough meat there but this would screw up the camshaft sensor and camshaft relationship.
Thanks for listening.
Steve C.
Steve C.
