On Center oil pan...
STP
Narrow A$$ Racing
Short of buying one from CAS, what are my options for a wet sump pan? TIA
Buy a plain old 14-bolt pan, and have a pickup welded into it, on the passenger side near the bottom of the sump. Either put some sort of screen on the inside, or an inline screen on the outside. Run a -12 line to a Duttweiler oil pump setup. Costs about $300, but EZ.
Thx for the reply Mac...I have an older stage 2 on center with a pickup in the block, so i was planning on utilizing that rather than go with the duttweiler setup. But, the dutt. is adjustable and easier because i would have to fab a pickup and braze it if i used the pickup in the block. I was looking for aftermarket pans only because I was considering a windage tray for performance. I've got a couple 14 bolt pans i could braze a fitting onto...I guess i'll go that route. Thanks again
Hey Narrow ass............
get hold of Leeo.....he's making some deep pans up right now
