ibroussard
- Dec 5, 2004
Razor,
As an example, I looked at the actuators on Cotton's website. They show an HD actuator with a range of 18-30 psi (as you mentioned), and a standard actuator with a range of 12-22 psi.
So does that mean that if I want a minimum boost setting of 12-14 psi, I can't get a max boost setting of anything above 22 psi? And if I want a max boost setting over 22 psi, I have to accept a minimum boost setting of 18 psi? So min 12 max 24 is not possible? This is also assuming a stock turbo, or maybe a TA49.
Thanks,
Ira
Thanks,
Ira
