Jan Larsson
- Nov 22, 2001
Julio, for the cylinder heads. We looked at this today and the 1.75 spring height for the beehive springs should work out fine.
We also like to use the comp cam spring locators (hardened steel alloy seat) to make sure to protect the head and also locate the springs correctly. This instead of just using a thin steel shim for the spring to sit on.
The thickness of these locators are 0.060"
Question is how much can we mill the spring seats on the TTA OEM heads safely without any risk to hit water?
