Sleeper1987
3.8L of Fun!
- Jun 11, 2006
Well my day started of with a loud ticking noise after i merged onto the freeway this moring and the car broke the intake rocker on the driver rear cylinder lots of knock retard at cruise. So i search all day and find a new rocker at of all places autozone (melling part).
ok so I get the car back together inspected all pushrods,rockershafts etc, pulled the spark plugs they looked pretty worn so i grabbed a new set of autolite 23's ( replacing r42ts ac delco's) at autohole gapped them at .030 thou (same gap as old plugs)
below is a picture of the plugs, the light color plugs has about 500 miles on it (broke plug changing manifold gaskets) and the rest are milage unknown.Look normal to you guys? no detonation shown on the plugs
(The Problem)
The car is surging under boost in hi gear (3rd) boost is set to 20psi (93 octane ) no Kr noted on scanmaster not even at shifts. The o2 mv drops to .058 in 3rd gear 7.97 in second 8.30 in first 5,200 rpm shift points.
Anyone have any ideas what has happened?
(The Problem)
