One stop shop?
84GNwith87eng
This spring the GN will be getting made into a reliable driver, I need to go through and most likely replace all of the following...
upper and lower ball joints
all tie rod ends
center link
idler arm
control arm bushings
Is there a certain place anyone reccommends to get all of these parts? I know they're not that expensive so if anyone can point me in the right direction, it would be greatly appreciated
thanks in advance :D
well for stock replacements pretty much any autoparts store will have that stuff.
if you are lazy and like the internet then go to www.gmpartsdirect.com
if you want to upgrade to poly bushings or whatever the hrpartsnstuff is the place you need to go to.
Ok...should I be able to obtain those part numbers off gnttype.org in their big parts list? Note: my car is an 84, so will there be any difference in the front suspension parts as opposed to any 78-87 g-body? I don't see why their would, unless I wasn't using stock replacement parts
Thanks a bunch
Chris
