opera lights
If both your lights are out, check the 'inverter' in the trunk. DO NOT check it with a 12 v. test light! If you look closely at the green relay underneath the package tray, (between the rear speakers) you will see it has a tag on it ,110v. One of these can be found in the trunk of many Olds. 88,98's ect.
