Optima Red problems
While I am of the belief that the red tops are not the ideal choice in batteries for a daily driver, I also believe that the yellow tops are the way to go IF you need an Optima.
However, most of us aren't independently wealthy and cannot afford the yellow's.
Optima Red Top
I installed a Red Top in our '84 HURST OLDS in 1990.
The car went from a daily driver (25K mi) to a near never driver.
Finally replaced the battery (15 years old ).
Never disconnected it, but invested in a Deltron Battery Tender Plus.
Battery Tender has saved me alot in battery purchases.
I just hope the new battery is at least half the battery the first one was.
Without occasional driving , a battery tender can save you a fortune.
I have KILLED several Great Batteries. I.E. Sears DieHard Gold , Interstate , AC Delco.
Also used a Red Top in a Syclone about 8 yrs. ago and it is still doing o.k.(also on a Battery Tender when not being driven or raced)
GOOD LUCK, What every you choose
:eek: I've been through 3 red tops - 2 of which were bad off the shelf - I'm not impressed so far. Looks like there is a real trend here?!?!
Interesting thread. Especially since I run a red top in the race car that can sometimes sit all year long whilst waiting for partes (really it's money for parts). I have noticed over the years of playing around with this battery that if I let the battery sit too long (about 2 weeks) it will have discharged quite a bit. If I manage to get the car started, the battery will charge, but will not have very much reserve. If I then put my automatic trickle charger (2 amp) on it for about a week. The reserve will come back. The battery is back to acting like new or close to new. I do try to just keep the trickle charger on it at all times, but sometimes I have to use the extension cord for other things and I forget to plug the trickle charger back in. I have been through this scenario more than a few times and the battery, so far, has always come back to an acceptable level. Usually, over 12.6 volts. I think the trick to these batteries is to not let them discharge too much and always keep them on an automatic low amp (2 amp) trickle charger or tender. I like the safety of the dry cell. Also, less corrosion problems.
