I'm installing my spearco intercooler, putting in brand new 32lb injectors and getting a tune. The only mod my car has is an 87 ECM. I have not adjusted the boost in any way. I want to order a chip from turbotweak because I have a stock 87 chip that is probably not making my hot air run its full potential. I just want to install my intercooler on my car and I dont plan on cranking up my boost until I get a new fuel pump and adj. regulator. A stock hot air runs 12 psi stock, correct? If I order a chip and say I want to run about 15-17 psi in the future and only run 12 psi now, will that make it run poorly? Or should I just order the chip and say im running stock boost for now, even though I have an intercooler. Sorry if this is confusing.
Should I wait and just get the chip until I plan on cranking up the boost?
Rob
Rob
