Oring for fuel pressure regulator
iwantatta
The little rubber oring that goes with the fuel pressure regulator is cracked and i need to replace it and i'm not sure about the size. It an Accufab FPR.
Simple part but getting little help at the stores. I've tried napa, oreilys, autozone, and the dealer and even showing them the part. Napa had an assortment of them but they look thinner than the original one. Hopefully someone can point me to a link or something or the correct size.
Its for a TTA but i assume the GN uses the same.
I found these but am not sure its the right one and it seems kind of expensive.
NEW 84-87 GRAND NATIONAL FUEL FEED RETURN LINE O-RINGS | eBay
es70599 is the oring to the fuel rail, same as the fuel injector oring
for fuel return line doesnt matter what regulator , it uses the smaller fuel line oring that comes in a kit from borg warner or neihoff part #27478
heres an orieleys link but its available through local parts suppliers
BWD 27478 - Fuel Line O-Ring Kit | O'Reilly Auto Parts
Thanks, got it. They even had it in stock. Should have just asked you guys first. Probably confused them to bring in the FPR. I should have asked for the fuel injector oring. Now hopefully my leak will stop.
I got new ones from Rock Auto, got them, and the fuel line orings by the frame rail.
Standard Motor PN SK27 and SK26, both have 10pcs of each, for less than one dollar per SKU. Less than 2.00 for 20 total. :)
