b4black
- May 24, 2001
Originally posted by pat83t
With the WOT blasts, I got all the way up to 21 degrees retarded in the knock sensor.
I would be willing to bet most/all is false knock. Try grabbing the bottom of the DP by the converter and shakeing it. You'll likely find it can move around and bang into things. Also, open your hood and power brake the engine. I will probably move quite a bit. False knock won't blow headgaskets, but it will pull timing out.
