usetaboost
SAY CAR RAMROD!!
 - May 4, 2005
You learn by doing!  A haynes manual would be a good investment for you also.
SignUp Now!It may look intimidating at first but it's not that hard, really. You'll need some special tools but not that many to start with. The first thing you should do is to mark all the electrical connections so you know where they go and take some e tape and bundle the wires together so it's easier to put them back where they go. The camera is your friend and you can take pics when you remove something so you have a referance as to where it goes back on. Use baggies to keep your bolts in and make sure not to mix the bolts up.
If you can do your own brakes you can do this but it does take a little longer.
So pretty much take my time and stay organized. I feel better now. What should I buy for special tools?
Also I noticed my car seems to run at a high temp. My gauge says it runs around 250 degrees+? I was planning on swapping the themostat what size should I get?
Since you already have the 2004r tranny you probibly have 3.08 or 3.23 gears in it right now. It's easy to check so you may not need to change the gears, you might be able to get a better convertor instead. A little cheaper in the long run. I have a fuel pump saved on evilbay for around $20 and it's not the stock design if you're interested.
As far as the intake divider I'll see if I can post some sort of pic for you so you can di it yourself. Really basic and it's just a sheet of aluminum that you cut a couple of grooves in the intake to mount it. Very easy.
When you start tearing into the car take the rad to a shop and have it checked out for sure. If you need one get it but most of the time you just need to have it cleaned unless it has some bad leaking issue.
We'll be here when you need us I hope.
If I was going to do a converter I would just go with a stock D5. CHEEEEAAP
