Outlook Express Problem...
Chuck Leeper
Toxic old bastard
Staff member
HELP!!the delete function has crashed. I am attempting to clean out the "sent mess" folder. I tried the "cont/a/delete" setup.. too much data.. locked up.
Now, even after reboot, the "delete" function is inop, regardless of how I try to do it. Mouse, keyboard, rt clik/mouse, etc.
I've tried the delete function in the inbox, deleted items, sent items, and several other folders with "junk" in them.
This has been tried on 1 item, to 20 items... same results.. nothing! :confused:
Once I had found the system locked up, I cleared out, and restarted the delete process, doing only a few at a time.. Seemed to be working, but I now see that that process didn't work, either. All the deleted files are showing up again!
I even tried to drag them to the deleted folder.. Get an error: Cannot move this file.:mad:
Maybe someone can "enlighten" me?? [Short of shooting the keyboard operator!!]:D :D
If you're trying unsuccessfully to delete all of the messages in a folder you can go onto the hard drive and delete the actual file associated with the folder. Your folders will end with .dbx on the hard drive. There will be a 'deleted items.dbx' as well as 'whatever-you-named-your-folder.dbx' files. If you delete them from the hard drive then Outlook Express, not being able to find the original file, should create a new, empty folder when you open the program up. If you're worried about deleting the file, just rename it on the hard drive so Outlook Express can't find it - it will do the same thing. If you need to re-map the 'bad' file to the folder, just re-name it as the file name that Outlook Express is looking for (you can check the path for each folder by right clicking on it and selecting properties).
Jim
Got it..
fixed. tried it about an hr ago, and it worked just fine.
I had 3007 messages in the folder!!:rolleyes: ZERO now!:D
Thanks all, for the help!;)
