Oval Shaped Stock Driver's side Header
MCH86GN
I have an oval shaped driver's side header outlet. I have a new two piece TA crossover pipe on its way. Can/should I try and have the header heated and rounded or should I install mark uninstall the crossover pipe and header and heat the crossover pipe to conform to the header?
Or am I SOL?
I searched the entire forum and didn't really find an answer.
Or am I SOL?
Do you have a pic of the outlet?
Here are a couple taken with my phone.
Don't know how I uploaded so many pictures. Most are the same.
I would definitely try to fix the header, why chance ruining a new crossover? I think carefully heating with torch you could massage it back into shape (off the car of course).
From over tightening the flange - they do that.
Heat and a tail pipe expander - but not to expand - just to massage back to round.
20-30 bucks for the tool.
Or a muffler shop.
Indeed - like Tom said - header off.
Easier said than done - I know. :(
I suppose if you were really really good, and really really careful, you could do it from "down under"
Or a muffler shop.
Header is off, setting in my tool room. Where would you get the tool from? I guess I could search online.
Horrible Freight sells them.
You could try asking a muffler shop if they have a hand tool.
Wouldn't use a hydraulic mandrel though
I checked Habor Freight and they sale tail pipe expanders for $15 to $16. However, I have never used one and from the looks of the tool I'm not sure how I would use it to accomplish what I need. Time to watch a few youtube videos and see how people use these things.
They are pretty simple to use, if you are just expanding a pipe. It might be a little more difficult to use it to accomplish my task.
Those things don't work for crap on thinwall tubing let alone something that heavy. Take it to a muffler shop and have them use their hydraulic swedger on it. May have to heat it so it will keep it's shape...
I'll find an exhaust shop to do it. I may have tools here at my work to do it. Sometimes when we put our prototype transfer case on a vehicle, the mechanics have to make custom exhaust pipes.
It looks like that flange needs to get stuck in a press and flattened back out. If the ears are curled in, that should take out most of the ovality.
The flange is flat, I took it to a place S&K Exhaust and the owner took it back and put it on a hydraulic pipe expander. The owner just tapped it and expanded it a little bit and it is now in back in round. Best part, it was free.
