What happens if you run over 30 PSI boost with a 3 bar map using XFI...I'm assuming the settings at 30 PSI are used...so basically if you run 32 PSI the VE table settings from 30 PSI will be used...so you can't tweak anything over 30 PSI...it that correct?...also just curious what static fuel pressure is good to use...the FAST XFI guide says 45 PSI...I need to check mine pressure but can't remember what I had set it at...thinking around 43 PSI...is it that important since XFI will compensate anyways?
