Originally posted by Eric Stage I
Thanks Bruce,
I'd basically like to delay full advance until spoolup is done to see the effects on the mystical "transitional" knock, when trying to use alcohol injection with high timing. I was gonna write the code to be similar to the burst knock retard code. Except instead of just subtracting X degrees from current timing for a specified time after x% tps change, it would force the timing to X degrees for a specified time.  With the existing "subtraction" method, who knows where the timing will end up.
I just don't know if I can alter timing (in the existing system) since that happens in the rom.
Eric
Wellll,
It would seem that your just looking for a launch assist and that is one of the features in the Extender Chips.   BTW, it works really well.
I'd think you do better with just modifing the BKR function,
Just a couple things to think about,
your using Alcky, OK, when do you turn it on?.
What areas in the code work in what way at PE enrichment?.
Maybe just set the WOT Timing table to operate at just a really high TPS value.   There is also a min LV8 for PE.
Lots of ways to deal with what your looking at.
The final additions of timing corrections are in the ROM.   So you can add or ignore stuff in there, but there is room in the EPROM to write some code, at the expense of lose of some oem function.
First thing you'll want to do is build an ecm bench.    It's easier to see a mistake on Direct Scan, then hammer on an engine.
