Overstock trans STUFF @ BG
Lee Thompson
I have some trans and trans parts that I need to unload.
1-BRF- trans with welded forward drum
Large Alto band
Billet anchor pin
Blueprinted 10 vane pump
Hardened stator
TCI shift kit
Alto clutches throughout with extras in 3rd & 4th
Kolene steels in direct
Deepened stock pan with custom deep pickup
L/U trans with precision L/U tube in pump
This trans has been mid teens last year--Freshened over the winter
$1000 --no core charge--FIRM--will deliver to BG IF a non refundable deposit is recieved before May 14th.
Will this work with a precision single disc convertor or the does the pump kit require a multi disc?
Yes, it will
Actually will work with ANY L/U convertor. Just that precision started recommending it when they went to the multi disc (I believe). Supposed to pull the fluid out of the L/U bore to allow the clutch to engage quicker. Could be used as a NL/U without removing the Precision L/U kit but would have to change other spools in the pump. Thanks
